Linked Model Only Showing in Some Views
veronicaZ9YV6
Observer Observer
Message 1 of 10
veronicaZ9YV6
Observer
Observer
My linked model is showing up in some views but not all. I have checked to make sure the phasing is the same, worksets are correctly applied, and the view templates between these views seem to be similar. Display settings are "By Linked View".
Replies (9)
Message 2 of 10
Are those "some views" from the same level or different levels?
Message 3 of 10
veronicaZ9YV6
Observer
Observer
The same level.
Message 4 of 10
Does it show if you reveal hidden elements?
Message 5 of 10
veronicaZ9YV6
Observer
Observer
No it does not.
Message 6 of 10
fabiosato
Did you check the phase filters?
Fábio Sato
Message 7 of 10
amy
I believe by using revit links - by linked view on each page you would need to adjust which view it is looking at. If it's the wrong view maybe you wouldn't see anything if it's out of view depth range?
Message 8 of 10
amy
Check which discipline (in the properties dialog box) your view is set to (Arch, Struct, Mech, Elec, Plumbing, Coordination). Try setting it to coordination
Message 9 of 10
curtisridenour
Did you check the instance and type workset of the link? It is possible you have a different workset for type than the instance? If the instance workset or the type worksets are not visible in the view, the Revit Link will not be visible.
Message 10 of 10
efoxSMI
Did you look at the Revit links tab in your Visibility/Graphic Overrides or in the view template?  That link could simply be unchecked in your view.
