hi all
When adding a light system warns Lighting Equipment.
How I solve?
What parameters should I modify?
Solved by CoreyDaun. Go to Solution.
Your Panel is just not assigned to a Distribution System. Select your Panel and a pull-down will appear on the Options Bar (just below the Ribbon) which will allow you to select a valid Distribution System based on the data of the Primary Electrical Connector of the Panel. By default, newly placed Electrical Equipment is not assigned to a Distribution System, so this must be done manually.
Thank you CADastrophe.
