- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
i know Revit has the limitation that the Lighting Calculation Luminaire Plane is set by the lowest fixture. IS there a workaround to trick fixtures into not being seen a fixtures?
In a high-bay space I added an Exit light and the plane came down to 8'. I noticed when I move the light source in the EXIT family up (as it dosen't contribute to light anyway) i can trick Revit in not using the EXIT light as the lowest fixture. Deleting the "light source" didnd't work.
In some applications I have low-level floodlights, or step lights etc. So those could bring that Calculation plane close to floor level. Which obliviously will make things very wrong. Is there a way to make a light fixture to not be counted for the purpose of determining that calculation plane? I don't want to convert them to a different type of family.
I know Revit isn't a complete lighting software, but the Revit lighting tool is handy when doing a first layout.
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
