Light Fixtures not cutting voids in the Linked Architecture model
Message 1 of 16
Hello everyone,
I'm working on a project with Revit, I linked the architecture model to my project that I work on, but when I place a light fixture family on the ceiling the family can't cut a void in the ceiling as I get when I work directly on the architecture model without linking it to another model, Someone please let me know if there is any way to solve this problem (see image for more clarification)
Thanks!
Accepted solutions (3)
Replies (15)
Message 2 of 16
RobDraw
You would need to edit the architectural link. There isn't anything you can do to change the linked file from the referencing file.
Rob
Message 3 of 16
MuirEng
We routinely insert recessed fixtures into our models which rely on linked RVT. It works just fine.
Since you say this works for you if you are hosting the light in your own model the family should be ok, so it must be an issue with the way it is hosting in the linked file.
Without seeing your model I can only offer a few suggestions.
In an RCP view try picking up a light fixture and then attempt to host it to "face". What happens?
If you like post your RFA file and I will run a test with it.
Brian Muir, P.Eng, Muir Engineering
Message 4 of 16
You cannot cut any elements in linked models. Period. Architects often copy monitor light fixture from Electrical model to Architectural model to cut the ceilings.
Message 5 of 16
MuirEng
Ok, you are right!
I checked and our recessed fixture families (e.g. pot lights) sit inside the hosting surface with the mounting flange visible but do not actually cut the host. In practice this doesn't bother us.
Message 6 of 16
Mohamed-Nassar
Check your Family Category and parameter Cut with voids when loaded when Loaded in project.
Best Regards,,
Mohamed Nassar
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
Message 7 of 16
Thank you,
I already cheked but it't dosen't work with linked models
Message 8 of 16
Mohamed-Nassar
Is your Family Face Based?
Can you send the Family, May i can help you sir.
Message 9 of 16
Here is the familly
Thank you
Message 10 of 16
Mohamed-Nassar
all right,,
in the Elec Model which it has been Linked the arch model you can not cut with voids but when it loaded in the Arch model i can be.. this a new consider thanks and this is what happens in Navisworks also we find clashes between Elec Fixture and Ceiling but we grouped them as Dummy or host clash.
pics will show this also
Best Regards,,
Message 11 of 16
Yes, with naviswroks it doesn't bother us, but in revit we lose the realistic visuals of most lighting fixtures families especially downlights
Message 12 of 16
iainsavage
@RobDraw  and @ToanDN have answered the original query and I would think their posts should be marked as solutions. The rest of this thread is chat and speculation.
Message 13 of 16
Scott_D_
Have you tried putting a Void Extrusion in your family that doesn't cut anything in the family, but may cut the ceiling?
I played around with this a long time ago and can't remember off the top of my head if it worked or not.
Message 14 of 16
RobDraw
It's already been stated and confirmed in this thread that there is nothing that can be done to the linked model from a family.
Rob
Message 15 of 16
Sahay_R
Tagging in to this old thread - what worked for me was to make a part of the geometry of the Light family visible in plan and reloading the modified family into the Elec model. That showed the position of the light fixtures in the architectural RCP.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 16 of 16
iainsavage
That might work visually but it still won't cut a void in the ceiling in a linked file.
You could use this tool but be aware that it will alter the architectural link which the Architect might not be happy about?: https://agacad.com/products/bim-solutions/cut-opening/overview
