Light-fixture schedule: calculating totals of counts?
cjacobsLDX59
cjacobsLDX59
Hi all,
I'm trying to make a light-fixture schedule on a large Revit project. I want it to calculate the totals by light type (family and type) per level. However when I choose to calculate total under "Count" when making the schedule, it still comes back only returning 1's in that field.
I'm new to schedules in Revit - could there be some sort of simple mistake I'm making?
All help is appreciated :)!
Thanks in advance,
If you want show the same Light type in one row with the total Count for that type, then:
- Sorting/Grouping tab:  Sort by Level then by Family and Type; Untick Itemized every Instance box
- Format Count to Calculate Totals (which you did)
iainsavage
Same as this but sort by Family & Type and then by Level (or vice versa depending on how you want it):-
https://forums.autodesk.com/t5/revit-mep-forum/including-levels-in-a-light-fixture-schedule/td-p/109...
Gives:
Or
Gives:
