Light Fixture Parameters Showing Same Results
Message 1 of 22
I'm trying to schedule out a bunch of parameters with my light fixtures. But, a bunch of parameters have results that make no sense. They are all the same results for that parameter. All these parameters:
Wattage
Total Lamp Lumens
Total Light Loss Factor
Luminous Intensity
Luminous Flux
Luminaire Lumens
Luminaire Input Watts
Lamp Lumens
Initial Color Temperature
Luminance
Efficacy Rating
Efficacy
Dimming
Any ideas why there are no varying results for these parameters? Some of the parameters I can't even figure out where the information is actually being pulled from.
Replies (21)
Message 2 of 22
Let's start with a few things:
1 - Are you using shared parameters?
2 - Did you build the family yourself?
3 - Can you send a screen shot of the schedule fields properties (where you go to add/remove fields from the schedule)
We'll go from there!
Message 3 of 22
Scott_D_
Stock revit families for lights have odd identical figures for light fitting parameters.
Are you scheduling the OEM fitting parameters or your own which are not working correctly?
Message 4 of 22
1. Not for the parameters having the same results
2. Yes
3.
I'm mostly concerned with the Wattage parameter being the same for all the fixtures.
Message 5 of 22
I'm only using parameters that are "built-in" lighting fixture families and parameters I create. The "built in" parameters such as Wattage. Are the parameters I am having the issues with
Message 6 of 22
What about in plan view or when you select the fixture, what do you see in the properties for those parameters?
Message 7 of 22
kadmonkee
are they all TYPE parameters?
try changing some to INSTANCE Parameters.
never saw this action before it seems odd.
can you manually change the parameter and its value after you change to an INSTANCE parameter?
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 8 of 22
fabiosato
Depending on how you plan to use these parameters data, they are not the solution, for example Wattage is a text parameter, so you can use it for calculations, personally I create my own set o parameters, specially because this way I can set the ones I want to instance type.
If you are having too much trouble, use your own parameters.
Fábio Sato
Message 9 of 22
No, I do not see the properties i'm having specific issues with.
Message 10 of 22
The parameters I'm having the issue with seem to be "built-in" parameters. They are not in the family. That are not showing in the fixtures properties window or type properties window in the model. I'm just curious where they are and what they are actually pulling. Because its just seems like arbitrary information.
Message 11 of 22
kadmonkee
can you share the family ?
thank you
Message 12 of 22
Sure. All our fixtures are created with the same parameters. So, I guess if one is not working. they all will not work. The family is in 2017.
Message 13 of 22
kadmonkee
i compared your family to the one i attached and have used for a while now with no issues.
i couldn't see any differences as far as parameters go (other than naming conventions)
the family is created in 2016 but feel free to update it
it is an unhosted multi type based family
generic in appearance but it serves many purposes and scenarios.
thank you
Message 14 of 22
Thanks. I'll take a look at it. My fixtures work great. All my shared parameters work exactly how I want them to. Lately, I've been trying to put together schedules for our engineers to utilize. So, I just dumped all the parameters available for a light fixture family into a schedule to see what information would be of any importance to them. That is how I came across the issue I'm having. I'm just getting a little confused where some of the "available" parameters for the schedule are actually getting pulled into the schedule and how they are getting the results they are showing. Because they mean nothing to me at this point. The Wattage parameter in particular is something that is just confusing me. Its showing 9W for all the fixtures. Obviously, that is not correct.
Message 15 of 22
kadmonkee
so i tested some things on my end
i created a shared Parameter (instance) for Wattage included that in my lite Fixt family and then added the parameter into my schedule
the fields will vary in your schedule but the shared Parameters need to be included in both the family and the schedule
Wattage Comments is Static (type Parameter) same value in a text field. built in parameters are limiting
if a formula can be added (not sure) for the the wattage to be calculated, i entered the random numbers
add the shared parameter into the project (Project Parameter) and assign it to lighting Fixtures
thank you
Message 16 of 22
Totally understand what you are doing on your end. My confusion is that there is a Wattage parameter already available in a light fixture family that can be scheduled. Its not a shared parameter. I believe its "built-in" to the family. If you build a new fixture family and do not add a wattage shared parameter. It will still show up as a parameter to be scheduled. Curious why its in there and what it is even doing. Because it just seems arbitrary. No real numbers applied to it. But, it can be used in a calculated formula in a schedule. Its just confusing me what that parameter is even doing in the family and why it is available to be scheduled.
Message 17 of 22
fabiosato
Hello timmy21,
I believe I understood your question.
Some parameters are inside some configuration windows, see the images below.
Fábio Sato
Message 18 of 22
Scott_D_
Revit uses the apparent power figure in VA from the electrical connector, that's probably why the Wattage parameter seems a bit arbitrary.
Message 19 of 22
Thanks. I stumbled on to that just yesterday myself. There are still a couple that I'm trying to dig into to find where the information is.
Message 20 of 22
fabiosato
Hello timmy21,
Depending on the light source type you select, other settings and parameters will become available.
Fábio Sato
