Hello all,
I am running into an issue with circuiting light fixtures in REVIT 2019.
What I want to achieve: 24 light fixtures on a circuit, 4 circuits total, light fixtures are 277V-1P
Issue I am having: When I circuit the first set of 24 light fixtures, everything shows correctly with the panel name and circuits under the "Electrical - Loads" under properties (HE2, 5). When I go to circuit the second set of 24 light fixtures, the light fixtures show the panel and circuit correctly (HE2, 7), but when I apply the wire to the selected fixtures, the circuits indicated are 5,7 with (2) homerun arrows off it. I double checked and made sure that all of these fixtures had no existing circuitry properties to them. Additionally, when I circuited the third set, the wire properties read 5,7,9. Please see snipit as reference. Does anyone know how to fix this?
Thank you,
Andruw
Unfortunately I do not think I would be allowed to do that
However, I have double and triple checked that nothing has been circuited to the panel via System Browser. It correctly shows the 24 light fixtures on each circuit, but the 23 wires for sets two through four show 2, 3, and 4 circuits respectively still. Could it be something related to the light fixture family itself? A sub-consultant is doing the light fixture layout
Additionally, the loads correctly show in the model. It's just the wires family that is essentially applying an N+1 count for each new circuit I create. I've tried drawing the wires in before and after connecting the light fixtures to the circuits
