If you change your LEVELS that was associated to an architectural model's TOS to their FFL in your own project will that create issues with the floor plans that are already created or will the views adjust to suit?
We have a floor plan that has parts of the floors above and below and it doesn't matter how we play around with the view range we just cant seem to get the floor plan correct as it was prior to re aligning the levels.
See the pic, which is of a 7th floor, but has parts of 8th and 6th on it...Should be View range I know!
Please help! Thanks!
have you check your underlay set to none. thanks
Hi @Anonymous ,
Have you got a solution or you still need help.
Please let me know.
no underlay enabled.....It turns out it was a glitch in Revit 2019............When we unload the link totally then reload the floors are as it should be....Strange...
So sorted, thanks guys
ok. thanks. maybe just untick your use hardware acceleration and see if helps. thanks
