Revit MEP Forum
Levels are cut off randomly
2 REPLIES 2
JaredFBJPDR
169 Views, 2 Replies
I am printing a shop drawing from revit and for whatever reason the text for the levels and level heads are getting cut off in random locations. I did a print preview and all the text and level heads show up fine. I am printing to bluebeam. Honestly this could just be a bluebeam issue instead but I wanted to ask if anyone else has had this issue and or has a solution for this.
2 REPLIES 2
iainsavage
in reply to: JaredFBJPDR
Try different pdf printers and see if the same thing happens. Depending on version there is also a built-in pdf printer now.
If those methods work then its your bluebeam that’s causing the issue.
JaredFBJPDR
in reply to: iainsavage
Yeah I went through and tried the different printer types to no avail. I think you're right that it's simply a bluebeam issue.
