lasso loop arrow head style?
Message 1 of 11
i have an annotative family for 3 phase Circuit Feeder tag
i would like to include a leader with a loop arrow head instead of the generic closed filled
can anyone recommend the steps needed
I'm lost with this one
thank you
Replies (10)
Message 2 of 11
L.Maas
Leaders do not have too much flexibility built in. However you can do a few things.
Inside the project select the tag family which you want to change. Then select Edit Type and choose a different arrowhead.
You have a small selection of different arrowheads. Until now (Revit 2015) you are not able to create your own arrowhead and are limited to the ones provided.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 11
abulla
There is a loop arrowhead, but you have to load it. Go to Manage -> Arrowheads and create a Loop style, pick the Loop arrowhead and the size, then you can use it in your project.
Message 4 of 11
thank you.
that was exactly what i was looking for
Message 5 of 11
L.Maas
Very good, you are right forgot to check over there.
Louis
Message 6 of 11
nsigrest_fiskcorp
can you make the lasso loop end longer? currently if i use this loop. it only circles 1 conduit at a time. i would like to stretch it out to show multiple things being lassoed and are at the same elevation with one loop. thanks.
Message 7 of 11
RobDraw
You  can only change the size as mentioned in the solution but I wouldn't make this one bigger, though. I would make a copy of it and change the size of the copy.
Rob
Message 8 of 11
nsigrest_fiskcorp
Message 9 of 11
RobDraw
@nsigrest_fiskcorp wrote:
i don't need it bigger i need it longer.
You can't do that with an arrowhead.
Rob
Message 10 of 11
nsigrest_fiskcorp
Ok thanks for the feedback.
Message 11 of 11
So technically you do need to make it bigger so it picks up more pipes. What I did is I made it larger and when I place the tag I change it from attached to free then I can move the loop w/o affecting the text. Seems to work ok for us
