To clarify further from the title, I essentially have tagged multiple elements with the same keynote, however, I no longer need the first instance of this keynote to tag the element it is tagging. If I delete the keynote, all of the other instances get renumber to the next number in the keynote sequence. Is there a way to prevent the renumbering from happening? I do have a solution, but there is an additional issue to my problem. The solution is to just delete one of the other instances of the keynote and just retag the first instance to the element of the deleted keynote. The issue is that I am working with two views. Let's say view 1 and view 2. I no longer need view 1 on the sheet, however, view 1 has a keynote that I still need for view 2. If I add the keynote to view 2 and try to remove view 1 from the sheet, the keynote gets renumbered since the first instance of the keynote is no longer on the sheet. Aside from the solution I mentioned before, the only other solution that comes to mind is to just remove all the keynote numbers following the keynote I want and retag all the elements to maintain the number sequence. Does anyone have any ideas for this issue?
Solved by iainsavage. Go to Solution.
I have always numbered by keynote so that you have consistent numbering across the whole project so number 10 on one sheet is the same type of element as number 10 on another sheet, but that was just my preference.
