- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
We have a Key Plan inserted into our title block. When in a sheet view, if we select the title block, the properties panel lists various parameters that can be changed including the visibility of a North Arrow, a plot date stamp, and which of the multiple sectors we'd like to be highlighted. There are also text labels that fall under the Identity Data category that are also visible and can be modified.
Once the title block is no longer selected, none of the previously mentioned yes/no parameters are able to be toggled, but the text labels are still available to be modified. I'd like to set up the key plan/title block so that the yes/no visibility parameters are also available from the sheet view without the title block needing to be selected. It would make it much easier to select the specific sheets in the sheet list and toggle their sector visibility all at once.
My only "workaround" for the time being involves opening every sheet that should have Sector A visible, tiling the windows, and then Ctrl+clicking on each title block before checking the box to make Sector A visible. Rinse and repeat. Not too bad when there's just a few sheets, but when there are quite a few it becomes a bit of a hassle.
Any tips on this would be very much appreciated.
