With multiple floor plans you would definitely need to use the Yes/No visibility parameter for Titleblocks. If the drawing set does not include a lot of sheets I would recommend using the Legend View approach it will take less time and won't require you to create any parameters. But if you have a lot of sheets in your drawing set use the Titleblock approach and control the visibility with parameters per sheet.
Jason Richard Evans | Project Engineer
SimplexGrinnell, A Tyco International Company
6240 Smith Road, Denver, CO 80216 United States
Tel: +1-303-355-0500 | Fax: +1-303-355-0615
[email protected] |
www.simplexgrinnell.comCONFIDENTIALITY NOTICE: This e-mail message, including any attachments, is for the sole use of the intended recipient(s) and may contain confidential and privileged information or otherwise protected by law. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please contact the sender by reply e-mail and destroy all copies of the original message. Any applicable rights to privilege have not been waived.
Tyco's vision is Zero Harm to people and the environment. Please consider the environment before printing this message.
________________________________
This e-mail contains privileged and confidential information intended for the use of the addressees named above. If you are not the intended recipient of this e-mail, you are hereby notified that you must not disseminate, copy or take any action in respect of any information contained in it. If you have received this e-mail in error, please notify the sender immediately by e-mail and immediately destroy this e-mail and its attachments.
