Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Its 2022 and I still can't find a way to change a Fabrication Parts Service color for Navis Export
2 REPLIES 2
jwlewis777
559 Views, 2 Replies
I have looked everywhere and still cant seem to do this.
I have no issues showing different colors for different Fabrication Parts Services like Roof Drains and Overflow Flow Roof drains. Each system is colored differently and looks great in Revit.
When I export to Navisworks 2020 or 2021 using Revit 2020 or Revit 2021, none of the colors are shown.
I have read every search result on this and the information out there is very confusing. Most are saying you can't do it. I believe those are old posts because the Navis model already has different systems colored.
Logically the correct way would be to create a material for that system and change the material for all instances of that system in the revit view to use that material. It seems this cannot be done.
Can someone please help me figure this out.
I would really appreciate the help!
2 REPLIES 2
RSomppi
in reply to: jwlewis777
You were right/wrong. Here it is:
https://forums.autodesk.com/t5/revit-mep-forum/color-filters-to-mep-fabrication-parts-to-export-to-n...
jwlewis777
Jeeez!
I did this last night...
Created a instance property called material that actually sets the material of the selected part.
Set a few of the parts new material property to a new material I created which I named the same name as the selected part service.
This did nothing to change the actual material of the parts in Revit, in any view or with any visual style. (I still think the only way to do this is with Dynamo Coding)
After I exported the model, it didn't change the color so I gave up.
Evidently I didn't change the correct color property, its the Shading color of the material that needs to be set. I changed every one of them except that one, lol.
It does work though! I really appreciate the info! You rock man!!!!
