Is there anyway to use GPU to render rvt projects? 4 GB dedicated graphic unused
Hi, I ask if there is a way to use the gpu and not the cpu to render since i've available 4 GB of RAM and none of them is being used to render, putting too stress on the cpu that heats and reaches about 80-90° C. However my Pc is pretty powerful so why don't use that power? I know that it's certified by autodesk etc etc but in many other programs even autodesk we can bypass this problem..
L.Maas
You might look at other renderers like v-ray (paid) which have capability of using the GPU. Maybe you have access to 3DS-Max which also have GPU based renderers
Louis
Please mention Revit version, especially when uploading Revit files.
