Is there a way to have walls not halftone when selecting an MEP view discipline?
MuirEng
Message 1 of 14
MuirEng
Selection of an MEP view discipline sets all architectural elements to halftone, but we really like to see walls show up clearly in plan in these views.
As far as I know the behaviour is hard coded and the workaround is simply "do not use these views" but it seems like a shame...Am I missing something?
Brian Muir, P.Eng, Muir Engineering
Replies (13)
Message 2 of 14
You could turn off Halftone for Underlay but it obviously affect all Underlay graphics.
Message 3 of 14
RobDraw
To add to what @ToanDN already said:
Object styles for starters.
V/G Overrides and View Templates are a close second.
Rob
Message 4 of 14
MuirEng
We'd like to see all other architectural elements halftone so turning off halftone for the architectural underlay defeats the purpose, but thanks.
Object styles not useful, the walls are coming in from linked RVT file.
VG overrides can change the line thickness of the walls from that linked setting but cannot override the way walls go halftone if an MEP view discipline is selected.
Cranking the wall thickness in VG and turning up the halftone preset globally gets us a bit closer but I think we'll likely just stick with the coordination setting.
Message 5 of 14
Is it for your coordination clarity or sheet printing?  If the latter, you can overlay another view set to Coordination, only shows Wall categories, and set to Wireframe, on the same sheet of the Mech view.
Message 6 of 14
RobDraw
Any of the above suggestions, or combination thereof, are fully customizable and are only limited by your required workflow.
Rob
Message 7 of 14
MuirEng
another way to answer the question would be "no"
Message 8 of 14
RobDraw
Or you could learn to control your modeling environment instead of letting it control you.
Rob
Message 9 of 14
RobDraw
No, there isn't a magic button to do this:
It took me a few clicks. I'm sure that is not what you are looking for though.
Rob
Message 10 of 14
MuirEng
Yes, it is possible to achieve the look I want using the coordination setting. My question is very specific, about the halftone override when I select an MEP setting. It cannot be over-ridden. Fine.
Robdraw, in future please do not reply to my postings. I do not find your advice useful and I do not appreciate your attitude.
Message 11 of 14
RobDraw
I did get the desired result with the view set to mechanical using methods stated earlier in the thread that you said don't work.
You also pretty much called me a liar when I was stating facts.
Good luck.
Rob
Message 12 of 14
RobDraw
You're doing it wrong.
You can absolutely control elements in a linked model with object styles.
Rob
Message 13 of 14
One issue with using Coordination is that some MEP specific settings such as MEP Hidden Lines cannot be used.  You can turn the view's Hidden lines to All but the hidden patterns are not the same.  But you maybe okay with that.
Message 14 of 14
Discussion_Admin
hey all just a reminder
Please remember these are professional forums and as such deserve a professional decorum when participating.
Discussion_Admin
