Revit MEP Forum
Welcome to Autodeskโ€™s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
IS REVIT 2015 THE SAME AS REVIT MEP
2 REPLIES 2
503 Views, 2 Replies
Greetings fellow Jedi ๐Ÿ˜„ Ahem, I am new to revit I just got my revit certified proffesional status, however we didn't go into the structute aspect and MEP AT ALL. Please tell me revit mep isn't a seperate program! Can you please give me some guidance because we only did architecture so it was just a glorified "the Sims" course and I know revit is far more powerful than that and I need to know more!
Many thanks and may the force be with you (Y)
2 REPLIES 2
scott_d_davis
There are different versions of Revit
Revit that is part of the Buildiing Design Suite is an "all in one" Revit that has Arch, Structure, and MEP included in one.
There are also Stand-alone versions:
Revit Architecture
Revit Structure
Revit MEP
Scott D Davis
Sr AEC Technical Specialist
dbutts7
There is a new MEP certification exam (took it last week at RTC North America) but it needs a lot of work. I'd hold off until Autodesk can tune it up a little, to actually test a user's MEP skills.
If you don't see the Systems tab on the ribbon, go to application menu (big R in the upper left corner) and then choose Options. Under User Interface, make sure the Systems tabs (piping, mechanical, electrical) are selected.
you can still buy it as a flavor, but we use the complete package. Somehow our MEP guys wind up doing a little architecture sometimes, too....
hope this helps - thanks - db
David A. Butts
Virtual Design and Construction Manager - Kimley-Horn
Revit Certified Professional/Autodesk Certified Instructor
Revit, AutoCAD Architecture, MEP, Plant 3D, BIM Collaborate Pro Subject Matter Expert
The MEP BIM/CAD Engineer Blog
