Is it possible to unbind the architecture file from revit mep?
Hi, I might have accidentally binded my architecture file into my mep file as a group. Now, I am trying to link a new file over but the binded file seems to be overlapping the linked file. Is there any way I am able to remove the binded file in mep? The second photo shows me trying to select the architecture linked file but to no avail.
Thanks so much
scbunker
I'm not sure what you're asking.
If you've put the linked file into a group, you should be able to select it and click Ungroup.
If you're trying to remove a linked model, you should be able to go to Manage->Manage Links, select the model and click Remove.
Just select the group (from the bound link), unpin, and delete it.
