Interference check using dynamo
I was trying to build a script for doing interference check in Dynamo and use those results later in my workflow.
If anyone has tried or could suggest where I can learn, that will be really helpful.
Thanks in advance.
Cheers!!
onBIM-Consulting
You can use the Dynaworks package to perform this. It use several functionalities of Navisworks directly on Dynamo. One of them is the clash detective
Thanks for suggestion,
I will definitely give it a try....
