Inclined reference plane - constraint
info
info
Hello all,
Please see following screen cast recording.
https://autode.sk/3zK1nb2
How do I create a reference plane that passes through intersections of other two reference plane pair.
Although I am able to create a reference plane, it is "not constrained" to the planes. Any ideas?
Thx
-Ranga
L.Maas
As the word already indicates. It is a plane. So it stretches to "infinity". It is only the symbol that stops at a certain point.
If you need to constrain the ends you should use a reference line. Those have begin and end points. The refernce line you will find next to the reference plane function in the family editor.
Louis
Please mention Revit version, especially when uploading Revit files.
info
Thanks. I tried but did not work properly.
Although I can draw 'reference line' on intersections of planes, how do I constraint (align) to inersections?
I cannot figure out how to do. The moment I draw the line, the pad lock disappears.
Please see below screencast..
https://autode.sk/39NknuD
It is weird that, in Revit, the end point of a line can only to aligned to one plane.. normally you need two planes to constraint a point (such as a endpoint of line)..
Yes you can constrain an end point of a ref line to an intersection of two ref planes.
- Use Align tool, tab on the 1st ref plane, click the end point of the ref line and lock.
- Repeat with the 2nd ref plane and now the ref line end point is constrained to the intersection of the two ref planes.
info
I solved.. please see the below screencast.
The trick is NOT to pin the planes in the first place.
https://autode.sk/3B0z4GU
