In the project Browser I don't have the - Mechanical- HVAC
alonitzan007
alonitzan007
I have a related quotation. In the project Browser I don't have the - Mechanical- HVAC. what can I do to bring it  back to the Project Browser?
You need to assign Mechanical Discipline to mechanical views then your browser will sort them under Mechanical category.
handjonathan
Hi @alonitzan007
Thanks a lot for posting your question to the forums!   Has the solution suggested by @ToanDN helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
hmunsell
by Mechanical - HVAC are you referring to the Project Browser or the Ribbon?
if its the ribbon
  • go to File, Options, User Interface
  • make sure its checked
if the Project Browser
  • right click on Views
    • at the top of the Project browser
  • pick Browser Organization
  • pick the appropriate option.
Howard Munsell
handjonathan
Hi @ToanDN
Thanks a lot for posting your question to the forums!   Has the solution suggested by @hmunsell helped with your issue?
Jonathan Hand
