Impossible to create a pipe connection in family
marco.defina
marco.defina
i don't know why i cannot create a pipe connection on the surface of the elbow.
BIM Manager - HVAC and Plumbing designer https://www.autodesk.it/content/dam/autodesk/www/products/responsive-imagery/responsive-badges-compare/2019/navisworks-manage-2019-badge-75x75.pngApp AutoCAD per dispositivi mobili premiumNavisWorks Simulate3ds Max___________________________________________________________________________
Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums.
fabiosato
Ciao Marco,
Connectors are only possible on flat surfaces.
Fábio Sato
marco.defina
It's a flat surface. is an imported 3D dwg. If i don't explode i can create connector, if i explode didn't work. I need to create a flat surface in dwg and not a solid?
fabiosato
Ciao Marco,
Try to edit a standard familiy following the screencast below.
Fábio Sato
marco.defina
I know this sytem to create segments.
But see what happens below. It's strange. I cannot select the face of the elbow after explosion.
fabiosato
Ciao Marco,
I never user other formats in Revit to avoid larger size families and this kind of problem.
I have seen some recommendations not to explode AutoCAD files because their may create a lot f garbage, can't you create referente lines and a sweep in its place.
I have created different approach family frame, check if it is OK.
For your use, may be enough, but you can make it more complex to group the solution.
Fábio Sato
marco.defina
I will take this example for the future. Thank you.
