Imported AutoCAD line weights differences are not distinguishable when Revit sheets are printed
erginmc12
Observer
erginmc12
Observer
Observer
Imported AutoCAD line weights differences are not distinguishable when Revit sheets are printed. I do not have this problem from earlier versions of Revit.
iainsavage
Change the associated Revit line weight in Manage>Object Styles>Imported Objects, or in the visibility settings for each view/template.
hmunsell
@erginmc12 wrote:
...earlier versions of Revit.
what AutoCAD and Revit versions are you using?
Howard Munsell
erginmc12
Observer
Observer
Using autocad 2022 and Revit 2023. The first comment solved it. Thank you
