Revit MEP Forum
IFC options class mapping - works with opening IFC but nut with linking?
5 REPLIES 5
shundt1
294 Views, 5 Replies
Hello everybody,
we got a new project and at the moment we give the openBIM with ifc another try. I think I'm constantly understanding more and more about IFC and Revit. But right now I'm faced with a situation I don't understand and I hope you can help me.
Here is the situation:
I want to exclude some of the ifc-classes while linking the ifc-file from the architect. So I opened the IFC-mapping table and there I got to the IFC-class named "IfcOpeningElement". As I remembered I entered "DontImport" in the column "revit category". Here the screenshot:
So far so good. Now there is this problem:
If I open the IFC-file directly in Revit it works - so the opening elements were not included in the model. Here the example:
But I want to link the ifc-file within my MEP-project so I can change the ifc-file if there are any updates regarding the architecture. So I linked this ifc-file and now the opening-elements will be in this file.
So my question is:
Is it possible to exclude IFC-classes while linking IFC-files in Revit?
Kind regards
5 REPLIES 5
fabiosato
in reply to: shundt1
For more control, I always open the IFC and save as RVT file, I had the same issues in the past and I avoid them with this workflow.
I don´t know a way to do that with linking, unfortunatelly.
Fábio Sato
shundt1
in reply to: fabiosato
Hey @fabiosato
thank you for the idea. So you open the ifc-file, then save as a rvt-file and after that you link the rvt-file? I thought about this workaround, too. But in this case (i hope i remember that correctly) we're facing a problem when the architect updates the architecture, because the ID's of the elements will not stay the same in this case. And that's the problem for us: we need the ID's to stay the same for the calculation of heating/cooling load for example. Our calculation software doesn't identify the elements correctly with this workaround after the architecture gets updated.
fabiosato
In my case, IDs are not an issue, in this case, maybe editing the RVT file created when you link the IFC maybe an option.
Fábio Sato
shundt1
Hey @fabiosato
this workaround could be fine. But it is very time consuming. The architect generally changes some architectural things in the project. So I would need to look after every change in the original IFC and then I would have to make the changes in the firstly imported RVT-file on my own. There is a big risk that we don't see every change in the model or forget some changes besides the part that it is very time consuming. So this is not a solution for us. We would rather live with wrong class mapping at the moment due to the timelines.
But thanks for your ideas.
fabiosato
Removing the openings is quite simple and can be done quickly, if the file is not too big.
But  if you receive a new model frequently it maybe time consuming.
Fábio Sato
