I would like to add a parameter to a Connector inside a Family in Revit.
smlee0521
smlee0521
I am working on a Family in Revit and I would like to add a custom parameter directly to the Connector. Is this possible, or are Connectors limited only to their predefined parameters?
iainsavage
I'm pretty sure that cannot be done but if you describe what it is that you trying to achieve then maybe there is another solution.
RSomppi
You can drive the existing parameters with custom parameters but you cannot add any from what I can see.
