It was more a statement of fact, as in, Revit doesn't let you do it. Unless I am wrong and Revit does allow you to do it and I am messing up.
I add the air terminal(1) to the cav(1), which is system SA 1.
I add the air terminal(2) to the cav(2), which is system SA 2.
If I select both CAVs at the same time, the option to create a system is not available.
If I select CAV(1) I can create a system in which I select the AHU as the equipment. If I now select CAV(2) I can create a system but when I try to choose the AHU as the equipment, I cannot (it is grayed out).
I select the 5 air terminals on the 3rd floor and create a system (SA 3) I can add the AHU as the equipment (SA 1 also has the AHU as its equipment)
I select the 5 air terminals on the 4th floor and create a system (SA 4), when I try to add the AHU as the equipment, I cannot (it is grayed out).
I don't know why I cannot select the equipment to add it to the system, that is why I am here.
I can't share the model, it's against company policy.
