I can't remove a reference line
Hi everybody, I can't remove or select a reference line in a MEP model.
1.JPGThanks for your help
sujanc
First check Pin/Unpin option, then go to the bottom right corner of the revit interface and unchecked the link, underlay, unpin options.
Hope this will work.
Please select "Accept solution" if the information was helpful (This allows other users with the same issues to find it higher in search results), or reply back if you need more help!
Switch to coordination discipline, delete, then switch back.
Thank you so much... It was an easy solution!!! 👍
Thank you so much! It was an easy solution!!!
latsadahapin
Community Visitor
Community Visitor
I encounted the similar issue but couldn't click on the Reference Line to unpin the line. It became freeze/hard to delete the line.
