Revit MEP Forum
How to use Duct & Piping Systems in filters
6 REPLIES 6
Radish_G
2435 Views, 6 Replies
Hi Guys,
Do anyone have an idea, how to use the "Duct and Piping Systems" in the filter.
Regards
Radish G
Tags (1)
6 REPLIES 6
rudi.roux
in reply to: Radish_G
Hi @Radish_G
I hope you are well! Smiley Wink
Firstly, I'm not a fan of filtering solely by "Duct Systems" as they honestly do not work the way you want it to in filters and your defined criteria under your filtering options is limited and you have less control over individual elements. I'm going to divert you to THIS POST which goes through what I'm going to show below in a bit more detail.
Option 1: (Filtering different Duct Systems)
I have control over the System Type Colors, the flex duct colors and insulation colors. There is a lot more that can be done by means of not filtering via "Duct Systems". The same goes for Piping Systems...
Option 2: (If you want a quick way to "color code" each duct system individually, rather use System Color Schemes)
I hope this helps! Smiley Wink
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
Radish_G
in reply to: rudi.roux
Hi @rudi.roux,
I am fine, thanks, hope you are doing good as well.
Glad to here from you, after a long time.
Okay we will come to the subject.
You said, "Duct System" in filter will not work in the way i want, Okay I agree with you.
And, at the same time, I am too curious to know the function of this "Duct & Pipe Systems" in filter. If you can, please brief me, or if you got any resources to understand this, please share with me.
My ultimate goal is to control the visibility of all the elements in a particular "SYSTEM TYPE". Which includes, mechanical equipment as well.
If you got any solution to achieve my goal please let me know. It will be a great help for me.
Regards
Radish G
rudi.roux
Hi @Radish_G
Yes, projects have been keeping me busy over the past few months Smiley Surprised
I'll try to answer your question and hopefully I make sense.
Duct Systems aren't physical elements, merely entities in Revit which helps Revit and the user to understand which elements belong to a certain "group/system" within the project. Because of this, the fact that they aren't physical elements, a proper color filter can't be assigned to them. A Duct or Fitting is a physical element which can have a color assigned to it. It has a physical appearance/material type in real life and a Duct System does not. Think of Radio Frequency (or Waves), they are non-physical elements, but they are there and serve a purpose as a communication method between two similar devices for example.
You have 3x options to control the color per "SYSTEM TYPE":
  • By means of Filters, as per my first post, the second image. There you need to select the physical elements which you wish to assign a color to. (Best option for me, most control over visual display).
  • By means of using the DUCT/PIPING SYSTEM TYPE PROPERTIES and Graphic Overrides. (Images below, not my favorite option as there are other graphical limitations).
  • By means of using System Color Schemes. (As per my first post, not ideal as you have the least control over lines).
This image below depicts how Ducts Systems can't have a color when only trying to filter it as it is a non-physical entity:
Lastly, to answer your question about filtering Mechanical Equipment. Remember, there can be multiple system types coming out of one mechanical equipment instance. I normally create a filter for mechanical equipment so that all of my equipment is the same throughout a project. Regardless if there is only one system type or 5 coming out of it. Have a look at my first post which illustrates this. (You have a Supply Air and Return Air System Type coming out of the Water Source Heat Pump and there is also Piping Systems which need to be connected to the Mechanical Equipment).
I hope this makes sense and helps!Smiley Wink
Rudi Roux
LinkedIn
Radish_G
Hi @rudi.roux,
Glad to see your reply. And so sorry for the late reply.
But, I wish to say one thing very clear "My intention of filtering is not to color the elements. I want to show/hide those elements of a  particular system type."
For e.g.,
I got two system types,
1. Supply Air Duct-1
2. Supply Air Duct-2
But, both system types, classification is same, which is "Supply Air"
Now, I want hide the system type 1 which is "Supply Air Duct-1"
Please take note, each system got variety of elements, which includes mechanical equipment as well.
Following screenshot for your review, also attached the sample project file for your review.
Do you got any workaround to achieve this?
Regards
Radish G
rudi.roux
Hi @Radish_G
What you could do and as far as I'm aware to achieve what you are looking for is to assign a dummy parameter which points to your family categories of your choice or as I outlined in the images below. This will then enable you to achieve what you are looking for. I prefer to use Shared Parameters as they are more flexible. In the outlined samples below and in the attached "Revised Sample Project" I used a Project Parameter. (Which will also result in achieving your end result).
I'm not sure how big your project is or how many systems you have in them. To achieve this, you would need to "TAB" each system type until all elements is selected, then assign that system type name to the newly created parameter which points to multiple selected categories.
Then a filter needs to be created and you will "FILTER BY" the newly created parameter which will point to the same categories.
The images below will elaborate what I'm stating above in further detail.
I hope this makes sense and resolves your issue. Smiley Wink This would be the only way I know of to achieve what you are after.
Rudi Roux
LinkedIn
Radish_G
Hi @rudi.roux,
Thanks for your reply, and so sorry for the late reply.
I tried this as well, but the problem here, which requires manual intervention.
There is lot of potential for human error, and I experienced as well. That's why, I looking for some solution to automate this process.
Regards
Radish G
