How to turn off light sources with self-illuminating material assigned to them?
I render an exterior scene in daylight with lights turned off, however the light sources have been set to a self-illuminated material and appear as the lights are on, as shown in the image.
I don't want to have to change the material of the light source just for one render, besides there are lots of different types of light sources with different self-illuminating materials assigned to them.
How can I adjust this to make the self-illumating material vanish, so that the lighting fixtures will show as powered off in the daylight render?
rudi.roux
Hi @Anonymous,
The problem lies with the material itself, being self-illuminating. The material is available to be used for obvious reasons, but with daylight renders it is a problem as you noticed.
Unfortunately, even if you turn off the dimming of the light in the Artificial Lights Rendering Dialog Box, the material will still self-illuminate.
What you could do is the following:
  • Duplicate the family, by the look of things you're using a "Wall-Mount Round Bulkhead" family which has a self-illuminating material assigned to it.
  • Go into your family editor and assign a glass material to it. (Change the reflectance/glazing of the material as you desire).
  • Save and load the family into your project.
  • "Select all Instances" in you project and change it to the modified Bulkhead.
  • Render you Scene and then change the bulkheads back.
OR Either set that material to an instance parameter or set it as a type parameter and make two types... Either way, you will have to flip the family before each rendering...
I know you didn't want to change the materials, but this would be the easiest and quickest way of doing things to achieve your end result. (As far as I know - as there have been quite a few similar questions over the years, all with similar advice as mentioned above).
I hope this helps! Smiley Wink
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome
