How to make a pipe tag identify if the pipe is a riser or not?
Contrerasj45MS4
Contrerasj45MS4
Community Visitor
Community Visitor
Hi!
I would like to know if there is any way to make a pipe tag to identify if the pipe is a riser. I have to make 2 different pipe tags: one to tag pipe risers and the other to tag a horizontal pipe in a floor plan. However, I always have to change the tag type for every pipe riser or horizontal pipe (image as an example), which is tedious for me.
I want to click "Tag by Category" and it automatically decides which Tag will be used.
Thanks!
iainsavage
The element category is pipe.
It will use the currently default tag type for that category.
You can change the default type here:
I suggest:
  • Set your horizontal type to the default, tag your horizontal pipes.
  • Change the default type to the riser tag, tag all risers.
RLY_15
Revit does not innately have a method that changes the tag type based on criteria (slope, in your case).
@iainsavage 's method is the most approachable method. I would probably manually tag the risers first so you can then run through the view with a length filter and tag-all the horizontal pipes of a predetermined minimum length (so that the annotations are readable).
Slope is unfortunately not an accessible parameter for V/G filtering...yet. If it was you'd use a filter to prune out any pipes whose slopes were less than 12"/12" or some similar high angle and be able to use the Tag-All command that way.
If you get into Dynamo in the future, the slope parameter *is* accessible in that environment, so you can batch tag using that method.
