Hello there,
I have a question about changing the color automatically for the family.
Currently, I'm looking for Mechanical Equipment that does not change its color automatically it needs to be the same material when I connect the Duct or pipe color. it needs to be in 2D and 3D View
I tried a two Different method
But I'm not getting the final result that I expected.
Ok, let's make it clear for everyone. When I do the above 2 methods I got the result
I need Everywhere the Mechanical Equipment looks like this
You may have been Questioning with Confused that already got the result then what you need more.
This has happened because the Revit itself got confused. This family is used to connect two systems that are Supply and Return air. The Revit doesn't know which color can be assigned to the family being a blind eye the Revit remove the overrides colors
If you have more than one system connection it's ok I can achieve But this is not happening all the time Look here
Please refer to the screenshot for the Different between the 2 methods. Screenshot named Mathods.png
Please refer to the screenshot for the first method. Screenshot named condition Filters.png
Please refer to the screenshot for the Second method. Screenshot named System Graphics overrides.png
Solved by iainsavage. Go to Solution.
You will gain more control without system graphic overrides. They affect too much without any flexibility. Filters are much more controllable.
Thanks for your reply, dear RobDraw. unfortunately, I didn't get a solution from the above replay
Yes, I understand that the filter is more controllable since they have a logical condition option. Doing that filter I didn't achieve the 3D model result
The duct color does not change. Do you know any idea how to change the Duct/Pipe in a 3D view? look here the screenshot please
I Agree with this Quote, If there is no solution for anything in Revit we can raise a New Idea the Autodesk team can implement in the feature updates
Regards
Rafilathif
You could add a dummy connector to the family for a pipe, then in the project connect a pipe to it and then delete it. The family will then have two systems and will ignore system graphic overrides.
Yes, this is also what I thought to make a family. But I have a Question making the Dummy connection will not make any impact on the Energy analysis, Pressure drops calculation, or heat and cooling load calculation?
Regards
Rafilathif
Make it Other classification, or Fire Protection Dry or something which will not affect calculations. I’ll test out a view filter later.
I checked filter settings using just Mechanical Equipment as the affected category and it works fine for overriding the system graphics - in this case I set it to black.
Is that what you wanted?
We were facing the same issue with all our Mec equip and duct accessories. We wanted the clearance zones to stay as "Clearance" material.
Below is the solution we came up with. We chose to add an electrical connector to family, but we use electrical systems in our projects so we assigned "Controls" as the connector type. This creates a dummy Controls connected system for each element, but as we dont use controls it hasnt caused any issues in the project.
Hope this helps.
