How to get Revit project units to round up.
andrew_muir2
andrew_muir2
Im currently trying to get my gpm units to round up, instead of to the nearest. please see snap shots for clarification.
the runtal is reading 2.310 gpm, and i want it to round up to 2.50 gpm, but revit rounds it to 2.25 gpm. any idea how to fix?
amarkonathala
Check by rounding the element to 0.5
iainsavage
The parameter value is presumably controlled by a formula in the family and you could, I think, use the roundup function in an equation.
It only rounds to an integer value so what I think you would do in a formula is divide the initial value by 0.5, roundup the result, then multiply this result by 0.5.
E.g.
2.31/0.5 = 4.62.
roundup(4.62)= 5
5*0.5=2.5
iainsavage
Of course if you want to keep the resolution at a quarter unit, change the divisor to 0.25 instead of 0.5:
2.31/0.25=9.24, roundup=10, 10*0.25=2.5
2.24/0.25=8.96, roundup=9, 9*0.25=2.25
etcetera.
