How to find duplicate elements at the same position
Sergio.Ramirez2
Message 1 of 9
Sergio.Ramirez2
Hi all,
I just wondering if there is some way to find duplicate elements at the same point and position.
I tried to do that via Dynamo but it only allow for familie components not for system family like ducts, walls, etc.
Thanks in advance.
I know that it possible in Manage tab and then in Warnings.
Replies (8)
Message 2 of 9
Hello @Sergio.Ramirez2
Did you try Interference check to find all the clashing elements?
Message 3 of 9
kadmonkee
if you suspect you have duplicates overlapping each other try selecting them (by window) and take account ofthe number listed in your properties.
another option is - create a schedule or use the system browser.
TAB select may help too.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 4 of 9
Hi @Sergio.Ramirez2  it would be great if you share that Dynamo script,  which you have tried.
Thanks in advance: 🙂
Message 5 of 9
L.Maas
Free Autodesk Addd-In BIM Interoperability Tools, Model Checker.
Great tool. Does a lot more checking and you can create your own checks if needed.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 6 of 9
thanks for your answer .........
Message 7 of 9
RobDraw
Thanks for the spam.
Rob
Message 8 of 9
anicholsdsi
Will this work with fabrication parts? or does anyone have a tool that does?
Message 9 of 9
rnasserWJUB5
Observer
Observer
Go to the 'Manage' tab, then select 'Warnings' under the 'Inquiry' Panel.
There should be the following warning:  "There are identical instances in the same place.  This will result in double counting in schedules."
Once you expand that message, you will see a list of all the places where this problem is occurring with them being labeled as 'Warning #'.
Then click on the 'Show' button to go to the particular instance where this is happening.
