Hi to everybody,
need to connect the vertical main duct to both horizontal,
I've tried with the command "Automatically connect" but the result is not what I've expected,
Also with fitting duct element, i don't get a good solution,
The vertical duct is
Any Ideas?
Thank you
g.
Place a section view so that you can draw from an elevated side view. Connect the upper duct to one of the horizontal ducts with an elbow. Select that elbow and click on the plus sign towards the unconnected duct to change it to a tee.
