How to apply view template for Plan region?
In my Plan region, I am not able to see pipe fittings, there are only pipes.
I am tried with View range settings but not getting the fittings.
I found there are worksets if those not on then those fittings will not come to the plan for this I need to open the Linked file to on the worksets.
Since the Plan region has no View Template option I can't access the Linked Model to on the worksets. There is no links in the VG of  Plan region.
What is the solution for this..
s.borello
Mess with your view range... upload a sample model so we can check it out for ourselves.
it's in BIM 360 Cloud I cant share its a large scale airport project.
RobDraw
Share just a small portion of it that exhibits the behavior or make a sample project that does the same thing.
Rob
You don't need to open the linked files to access their worksets. Go to Insert > Manage Links > Revit tab > select a link > Manage Worksets button.
this I can do for Plan view but inside my Plan region fittings not visible.
when I had this same issue in the parent plan I did the settings you have mentioned and it worked that time.
but for the plan region view fittings has no option to tick and enable worksets.
