How to apply material to conduit
BiMBoXiT
BiMBoXiT
Hi Guys,
I'm currently working on a cabling project in which I'm playing with the conduit category of elements to show the cables as trefoil formation. Due to some reason, I could not able to add material for the conduit which I wish to get on realistic view for visual purposes.  Anyone in this room come across this type of issue and please share your thoughts if you know anything better solution on this it will be beneficial for me and wider.
The attached image (A) color shows as filter options which I can't see in the realistic view
A) Shade
B) Realistic
BIM BOXIT
BiM BoXiT
mpeperkamp
Hi @BiMBoXiT ,
See this post by Rudi.roux:
https://forums.autodesk.com/t5/revit-mep-forum/how-to-apply-materials-to-conduits-by-types/td-p/6944...
If my post was useful to you, would you be so kind and accept is as a solution.
Others can see That and Find That information better.
Best regards,
Michiel Peperkamp
Cadac Group AEC
Cadac Group
Platinum Partner
BiMBoXiT
Thanks for your Reply.
The filter settings I applied earlier post refer to my image attached earlier.
certainly, the filter setting color won't appear in the realistic view and my interest is the same.
Expecting the best solution to get the results on a realistic view
BIM BOXIT
BiM BoXiT
juliar123
If you want all the Conduits to be one material, assign a material in the Object styles. If you need them to be different materials, then it's probably best to use the paint tool.
johnmichael_joseph
Community Visitor
Community Visitor
Change conduits line color and material in an object style setting.
venkatramanan_vs
Community Visitor
Community Visitor
Thank you, it's working, fine now.
Arunsundar_G
Observer
Observer
It's working good
