How to add additional HVAC service units
brianwclayton1969
brianwclayton1969
How do you add additional HVAC service units to the Systems lists for Heating and Cooling Load Analysis and Advanced System Settings?
See the attached pics
robert.klempau
Hello @brianwclayton1969,
As far as I know it is not possible.
They are hard coded.
You have to choose one of the list.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
brianwclayton1969
That doesn't make any sense, becasue I may have a new piece of equipment from another manufacture that isn't listed or a different type of VAV Unit or a different type of heat pump other than a water unit.
[email protected]
michael_coviello
Autodesk Support
Autodesk Support
Thank you for posting.  At this time, the ability to add this to the advanced energy settings dialog is not possible.
There may be options for tools on the Autodesk App store.
If you have comments about the software (features or improvements you’d like to see), please visit the new Revit Idea Station to let us know. You can also vote on ideas others have posted, so be sure to let us know if an idea you see there is important to you.
Michael C
Technical Support Specialist
What's New in Revit 2023 | Autodesk University | Revit Blog
brianwclayton1969
This poses a major problem when running Heating and Cooling analysis. Since some equipment you select doesn't match the equipment that you have placed in the project, when you run the Heating and Cooling analysis the information is already is incorrect and gives conflicting information, you should be able to insert other mechanical equipment to run analysis more accurate. In the advanced setting you are selecting whatever is there and those selections maybe outdated since Revit isn't updated with the latest Mechanical units.
michael_coviello
Autodesk Support
Autodesk Support
@brianwclayton1969
I understand how frustrating this is for you.   The ability to add to the list is not currently possible.
I recommend that you submit product feedback HERE. I urge you to mention the business impact that this missing functionality has as it can increase the chances of the functionality being integrated in the future.
Additionally,
Michael C
