How Revit define Home Runs?
fcastellonVRK5P
fcastellonVRK5P
I'm trying to add wires to my lighting drawings but Revit is not helping, at all.
It keeps placing home run arrows where it shouldn`t and it doesn`t give any option to change it.
Does anyones know how can I avoid this?
hmunsell
give this a try....
https://autode.sk/3hrpXtU
Howard Munsell
iainsavage
See part 8 of this page
" or click in an open area of the drawing area to specify a home run."
rclevyQW78G
Community Visitor
Community Visitor
That's not a solution. Autodesk needs to fix the feature so that you can select which you want as home run as you are creating it. Its extremely time consuming to set home runs for a hundred panels. We are dealing with a volume of work here with these projects.
iainsavage
You can create wiring automatically if you've created the systems and circuits but the OP wanted a method to control where in the system the home run arrow would be located. I think the solutions offered addressed that.
This is the official help for version 2025
https://help.autodesk.com/view/RVT/2025/ENU/?guid=GUID-267A4006-80D3-4306-A404-0AF77F3D49A8
https://help.autodesk.com/view/RVT/2025/ENU/?guid=GUID-553F57D3-F2A9-4FF8-BD95-C4C190728FEE
https://help.autodesk.com/view/RVT/2025/ENU/?guid=GUID-C2566440-B31E-47A1-A068-CB19CCCBB614
Take your pick.
