Family Type Selector box interfering with Modify toolbar
mfazioFRC73
mfazioFRC73
I'm having an issue with an additional family type selector box is appearing and overlapping with the toolbar I use to edit duct/pipe dimensions.
This box shows up in all views and even when nothing is selected. Does anyone know a solution to remove it?
curtisridenour
If you have multiple monitors and they are different sizes, sometimes the properties box acts strange. Change the resolution of both of the monitors to be the same or turn one of the monitors off to see if that fixes it.
mfazioFRC73
I'm using two monitors but they are both 24" @ 1080p. Only current fix is to restart Revit, and issue is appearing in both R20 & R22.
dbutts7
Can you post your system specs here - make sure you include graphics card manufacturer/model/driver version. Also let us know if you have all of the updates for Revit installed.
thanks - David B.
David A. Butts
Virtual Design and Construction Manager - Kimley-Horn
Revit Certified Professional/Autodesk Certified Instructor
Revit, AutoCAD Architecture, MEP, Plant 3D, BIM Collaborate Pro Subject Matter Expert
The MEP BIM/CAD Engineer Blog
