How do i link an architectural model with all its text and dimensions?
Hi everyone,
can someone tell me how i can link an architectural model for example into my HVAC model, but with all the texts and dimensions shown? When i link the architectural model i can only see the walls etc..
Visibility Graphics>Revit Links>"By Linked View'> choose ARCH view desired.
This is a view-specific thing, the default is "by host view", meaning that the default settings for your view will apply to the ARCH model in that view as well.
Hi bsammis,
yes im aware of that method but it requires me to pick a specific view from the ARCH Link. The Problem is for now we are able to use 1 Template View for every floor, so we don't have to adjust the filters and view settings etc. so if i would do it that way i would have to create a new Template View for each single floor wouldn't i? Which would be realy annoying since we have about 10 diffrent models that use the ARCH Link with 11 floors... or am i doing something wrong and you actualy are able to adjust the view seperatly from the Template view?
"it requires me to pick a specific view from the ARCH Link"
Yes.  Because dimensions, text, linework, and all other annotation objects are view-specific.  If you worked exclusively with an architect who always, always, always, had identical view naming conventions you could adjust your template in the way you describe, with a separate template for each discipline on each floor by creating a placeholder ARCH model, linking it into your template, and choosing the linked views you need.  I would strongly advise against doing this though, because that prerequisite will never, ever happen unless you work for a very unique firm.
You can adjust the linked view/model visibility setting apart from your template - I'm guessing your views have a template linked to them, and all of the V/G settings for model objects/annotations/linked models/etc. are gray when you open the VG dialog.  To fix this, in your view properties, find the "Template" line (the value will likely be "HVAC floor plan" or whatever you named it), and change it from the template linked to the view to "none".  This won't reset the VG overrides, it'll just make them editable.
In the future, when setting up your model, instead of choosing "Apply Template to View" choose "Apply Template Properties to View".  This gives you the basic override settings from that template while keeping them editable so you can customize the view to the project as needed.
I think the language barrier is a bit hard for me to overcome to get my point across properly. Ok i understood that the demensions are view specific which makes sense now that i think about it that they are not shown by default with the whole model. What i didn't quite understand yet is if i can have the same Template View for all my floors somehow and still asign a diffrent ARCH view to every single one of my views or not? If i click on the View Tab and then on V/G nothing is greyed out. I can adjust whatever i want BUT if i go to Revit links and then open the Viewsettings for my ARCH-Modell then everything in there is greyed out. I assume if i figure out how to make that edditable i get the result that im looking for.
Once you make it to the LInked model settings in the VG dialog, at the top you have series of boxes - By Host View (default), By Linked View, Custom.  Choose "by linked view" and you'll be able to choose any floor plan view in the linked model.
yes i got it thanks a lot 🙂
