Hiding, or turning connectors on and off
Due to my use of Revit MEP for plumbing, heating, and electrical purposes, I have visited many revit forums to search for answers when I cannot come up with one quickly. One constant problem that has vexed this side of the industry for a while now is the fact that there is no way to turn a connector in a revit family on and off.
I understand that this could be a difficult process, as that family is assigned a system classification based on its connectors. However, if multiple types of connectors are used, say for a boiler family, then the family will have multiple connectors and never be assigned a single system classification. Therefore a method to turn connectors on and off (since sometimes a boiler will have an exhaust or gas attachment switch sides) would be incredibly useful.
I have so far seen posts about this situation dating back to 2012, and it seems like quite a few people would love an answer to this. If it is possible to include a visibility parameter in the connector, that would be excellent!
2012: https://forums.autodesk.com/t5/revit-mep/pipe-connector-visability/td-p/3305965
2015: http://forums.augi.com/showthread.php?161883-Turn-off-connectors
L.Maas
Yes, would be nice. But then again, not a major issue (to me). Depending on the situation I deal with it in 3 ways.
1-Just create the connectors and use them or not.
2-Create different families with different amount/type of connectors.
3-Create separate (face based) connector families and stick them to the instances where needed.
Louis
Please mention Revit version, especially when uploading Revit files.
solutiointips
