Hi there, im studying Revit and im missing tools that are in my lectures.
Ive installed all programs (Revit, Navisworks, AutoCAD, MagiCAD - 2024).
The "tools" im missing are the following: MagiCAD- Common, Ventilation, Piping, Electical.
Ive reinstalled all the products a couple of times.
Ive googled and cant seem to find an answer to what is wrong.
The last step I did was installing MagiCAD Connect but that didnt change anything either.
Im attaching two files, the one is my teachers "tools bar", the other is mine.
Please help me. Its quite urgent.
Yours, Marcus.
Yours, Marcus.
Solved by iainsavage. Go to Solution.
This sounds like a MagiCAD issue rather than a Revit problem.
Most of the MagiCAD modules are, as far as I know, subscription packages which you need to pay for.
You should therefore probably check with your college if they can allocate you a licence seat.
