HELP ME WITH SHARED PARAMETERS
tmhNSR6A
Observer Observer
tmhNSR6A
Observer
Observer
guys , before this i have create shared parameters and upload to my main model . after 2 weeks , my laptop get virus. right now my shared parameters ( txt file in computer ) gone .  how i want to retrieve back my share parameters file ? i need to add on tagging. Please someone help me. if i create a new one ( make a same name parameter ) deleted the old one in revit file , then upload back , is that posibble all info that i key in will be missing ? Help me please
sorry for my bad english .
hmunsell
If you have a file that has the shared parameters in it already, they can be extracted to make a "New" Shared Parameter file.
  • Open the file containing the Shared Parameters.
  • create a new, blank, shared parameter file.
  • in a project, pick the Project Parameter option and select the parameter
    • if in a family pick the Type selector and edit the parameter
  • pick Export
  • the parameter will be saved in the "current" Shared Parameter file set in the Shared Parameter setting.
Howard Munsell
npsconsultingllc
The way above will work but best to download DirootsOne and use the Parameter Manager. You basically just open a drawing, open parameter manager, and export parameters. All of the parameters will be exported to a new file.
I don’t use the native Revit parameter functions for anything. It’s slow and tedious. Every time I use it in the past I’m left wondering why Autodesk hates its clientele.
once you’re done exporting it, you can use it to create new parameters forever. It’s free.
npsconsultingllc
Also, you can export them all at once. No need to click each one in every group.
craigjonnson
I came here to reply and saw that npconsultingllc said exactly what i was going to say. DiRoots One is free and their parameter tool will do this task for you.
tmhNSR6A
Observer
Observer
tq sir , you really makes my days. once again , thank you so much
