GRAPHIC HATCH PROBLEM WHEN PRINTING
rbejaoui
rbejaoui
Hi to you all,
when i change the transparency from 0 to 1  and print to PDF i found that the hatch is no longer there
when i do the same thing i have the hatch and all is correct but i found that the pipes start to hide when it s under another pipe
how can i fix this problem ?
hmunsell
in the MEP Settings, uncheck the Draw MEP Hidden Lines or edit the GAP parameters to make it more to your liking.
Howard Munsell
rbejaoui
Thank you @hmunsell  it works perfect .
