Hey.
Does anyone know how to add a flange within a spool of pipe.
I was looking to find a way to create a maximum of 10 foot flanged pipe, in which every ten feet, there is a flange on each end of pipe with a gasket connecting the spools of pipe.
Have sysque but they're having trouble as well with this issue. Looking for a solution asap.
Brian
Within revit? Not going to happen.
You'll have to create a flanged union and start splitting the pipe every 10 feet.
Brian, it can be done. See screencast below. It shows cutting in the flanges at 10' standard length and then putting in the flanged Anvil elbow. It includes the gaskets, boltsets, and joints (if needed on a short cut piece).
https://screencast.autodesk.com/Embed/Timeline/a6fa436a-561f-430e-97a7-73658ddfb02f
This will be in the new release of SysQue which will be coming out shortly. If you would like to see the system in action send me an email at
keastman@sysque.com
Only automatick way to do that is with addon SysQue
You can do That manual but you need to make a family for flange with bolts and place it every 10'. If you do that manual you can use multi copy with base element (plane line is good).
Eng. Iliev L.
⁞|⁞ BIM Implementer, Project & BIM Manager, Coordinator, MEP Engineer
⁞|⁞ http://www.TechRoom.bg
