Message 1 of 12
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have my system pumps in the model and I would like to be able to click to add my suction defuser, and get the outlet side to "snap" to the inlet side of the pump, sorry for the CAD terminology. I know its not a snap in Revit, probably host or work plane or something. If someone can make a screencast showing me how to make this happen I would appreciate it because I'd also like to do the same thing with my flex connectors and triple duty valves.
I attached the families incase you want to use the exact ones that I'm using. All of the pump models are in that family but the specific model number is: 40304x3x8125lb184TCTEFC
And the suction defuser is: SG-44-125lb
Revit lives in the land of perfect and doesn't understand what construction is.
