It seems to me that there should be applications in the MEP field for this tool but most of the information on it seems to focus on Architecture and furniture layouts etc.
Has anyone used it successfully on MEP problems?
How do you get started?
Solved by robert.klempau. Go to Solution.
Hello @iainsavage ,
Did you see this AU class from Sean Fruin?
Getting into the Flow of Generative Design for MEP
Thanks @robert.klempau I'll take a look at that later.
Anyone had any successes using generative design for MEP on projects?
Examples?
Hello @iainsavage,
I asked my contact at Autodesk if he knows of any examples for MEP.
Personally, I am also interested in this. 😀
As soon as he gets back to me I will let you know.
I took a look at the video that you linked.
It seems quite complicated, having to design, test, validate your own algorithms and programme them in Dynamo etc.
When the presenter said he had spent two years trying to refine one of his algorithms I came to the conclusion that I'll probably be retired before I get any practical use out of this - I think its one trick too many for this old dog to learn so I think I'll leave it.
