When I export my Revit model by spaces, it creates an XML file that contains walls, openings, etc. But the wall 'height' value is set to wherever the 'space interior fill' ends, which is usually the ceiling. Common load calculation programs need the 'floor to floor' height (or at least floor to bottom of floor above to be most accurate). Is there any way to get Revit to export this more useful value? It is saved on the space object, as Space > Constraint > Limit Offset. Are there any settings for GBXML export anywhere?
Even if those settings are text files or xml settings files, I'm interested (doesn't have to actually be a dialog box full of settings). Thanks.
My other CAD is a Cadillac and I like to Revit to the Max!
