filter into a dynamo script
Hi all
i always stayed away from Dynamo as it looked very deep and dificult to me.
Last week i gave it a chance and now I really like to creat script .
on my HVAC plans, I managed to create a script to number automaticly my Ducts and Ducts fittings.
My script catch the system abbreviation and mix it with numbers.
To make my script better, I would like to start the numer at 0 for each system.
To explain myself: actually on a plan with two systems (supply air / Exhaust air), my script create me a duct number SA-01/SA-02/SA-03… but also a EA-05/EA-06
Actualy, the number follow the last one doesn’t matter on witch system it is.
I would like to have a duct number SA-01 but also a EA-01
Do you understand me?
I tryed to select the elements but this node allows me to do it nly with selection not with the system (with TAB)
a filter node could be an option but I don’t really understand them,
Does anyone could help me please?
Baptiste
L.Maas
Good that you make th effort. You will not be sorry.
Something like this might do the trick to get you further
So what I do is:
-Extract the system abbrevation from the elements.
-Use those to group all elements with the same system abbrevation
-Use a count node to count all elements in a group
-Use the count to create a sequency (1 to count)
-Then create the string and store them in a parameter (I used comments)
Script attached
Note: When posting a question about Dynamo, it helps if you can also attach the script, saves recreating the script
Louis
Please mention Revit version, especially when uploading Revit files.
thanks Louis,
I finaly get where I wanted to go with the help of 2 colleagues.
We also used your strategy .
Here is the script for 4 different systems
MuirEng
try also researching / posting Dynamo questions at https://forum.dynamobim.com/
Brian Muir, P.Eng, Muir Engineering
