Filter elements only in Assemblies
fdkuenneke
fdkuenneke
I am aware of the ability to filter by element properties as normal, but is there a supported method to filter only the elements found in assemblies? Furthermore, if this is not possible normally is there a workaround to accomplish this in the API?
Thanks for any responses.
I'd say Revit was a chisel if it wasn't used as a hammer.
L.Maas
Elements inside an assembly have a parameter "Assembly Name" which you can use in a filter. Will that not work for you?
If you need additional options you could look into using Dynamo
Louis
Please mention Revit version, especially when uploading Revit files.
fdkuenneke
Not exactly (Although that is helpful),
I was hoping for a method to isolate or select multiple families (Drains / Pipe Accessories, in this case) without needing to individually select each one.
Dynamo would be a viable option if this isn't natively possible (although I'd have to dust off my Python coding!).
L.Maas
You probably will not need Python (immediately) when using Dynamo. It is a visual scripting tool, so most can be done by connecting nodes without the need for Python.
Louis
